On 1/23/2017 9:19 AM, Tom
Kerekes
tk@... [DynoMotion] wrote:
Hi Sam,
+5V power can be applied at
the other connectors. The IDC pins are rated for 1Amp.
If using ribbon cable try to use 26AWG ribbon cable
rather than the more common 28AWG. Use multiple pins
where they are available. Keep wiring as short as
possible. Consider using the KFLOP GND lug for +5V
ground.
I have applied +5VDC to pin 23 of JP7 and am using pin 25 as
ground. I have no USB or anything else connected to the
KFlop. I have removed jumper J3. I have also tried pins 24
and 26 to power and gnd respectively.
I get no leds on the KFlop. I'm certain the 5VDC power
supply is working well and good for 900 ma.
If I connect the USB to the computer and add Jumper J3, the
board works fine.
Am I missing something here in order to power the board from
the IDC pins?
sam marrocco | chief technical officer
ringside.cutters.flavor.picnic.moonlink
248 548 2500 w
248 910 3344 c
ringsidecreative.com
